Oil Cooler
Old Feb 20, 2014 | 05:40 PM
biohazarde's Avatar
Default Oil Cooler
I did a search, but wasnt able to find much. I have an inline pro oil filter relocation kit. It has the two extra an ports on it for a oil cooler. How does the flow internally on these adapters work? Basically i want to set up an oil cooler, and use a thermostat, so oil is not being cooled during the winter, or when its cold, so the oil can still get up to temp. Is there a specific way the thermostate needs to be hooked up to it (as far as lines needing to be connected to a certain port on the adapter)? i would be using something like this http://www.summitracing.com/parts/der-25719/overview/ it seems simple enough, i just want to know if you can get lines backwards, like you can on the other lines.
Old Feb 20, 2014 | 06:14 PM
s2k manic's Avatar
if you have the stock oil cooler still on the car there isn't much need I see oil temps average 200f on a 45f day and 230f beating on it and at 75f cruising temp 204-210 depending on speed I am supercharged so would guess an oil cooled turbo would put more heat into the oil
Old Feb 20, 2014 | 07:06 PM
biohazarde's Avatar
i do not have the stock oil cooler (no room) and in the summers here it is 100+ degrees
Old Feb 24, 2014 | 04:58 PM
conzetts2k's Avatar
Ask inline pro they will tell you if you call them. Tom at the shop is very helpful whenever I call there. I have a mishimoto 19 row oil cooler and I should be able to check temps this summer win I finally get the gauges installed.
