Oil Cooler Install on Turbo s2k
Old Feb 22, 2019 | 01:59 AM
  #41
pizzai69's Avatar
Originally Posted by markforrester99
Pressure wise i get the same as what i had before i had a cooler. When i had a cooler without the hole in the sandwich plate i would see 70psi during vtec and that was with AN10 sized lines. I was running a 19 row cooler. The way i figure it at low RPM and low pump flows most of the oil will bypass the cooler through the hole. When the engine starts revving higher the increase oil flow will cause the hole to gradually become a restriction and push more through the cooler. Its the perfect solution, very little cooling whilst cruising around and then alot of cooling when pushing on and revving high.
Temperature wise my sender broke but it noticed a decent decrease in temperatures. I dont need that amount of cooler nowdays with only road driving.
I think I will do like you: first test without the hole, and regarding the level of pressure I may drill a hole.
I found something new ine the Setrab documentation:
http://www.setrab.com/media/28769/Se...nce-graphs.pdf
And this is quite evident in fact: the shorter the row, the lwer the pressure drop.
So instead of gooing for a 235mm core length and 19 row, I am studying the possibility to go for a 115mm core length and more rows. The effect should be a low pressure drop, and quite reasonnable cooling.
115mm length and 25 row (estimated 15psi pressure loss) should approximately cool just like 235mm length and 13 row (near 60psi pressure drop estimaed !!)
Aturner87
Feb 7, 2014 03:50 AM
nissfam
Sep 4, 2012 10:43 AM
Ilike2DRIFT
Aug 24, 2010 10:12 AM
Rajdlos
Jul 8, 2010 01:04 PM
WtbS2k
Aug 19, 2006 08:45 PM
