oil cooler? relocater
Old Nov 2, 2005 | 04:41 AM
rick bailey's Avatar
Default oil cooler? relocater
how dangerous is it just to run the greddy oil relocator without the stock oil cooler? im thinking about going with the lovefab cooler but its 500 any cheaper ones that a good for turbo?
Old Nov 2, 2005 | 05:51 AM
Ztec's Avatar
The stock unit really is more of a oil warmer at start up then it helps cool as the oil temps peak - I bypassed my stock Oil/Water adapter to help control high oil temps at the track and it even helped my coolant temps since the coolant no longer had to cycle through the hot oil adapter. Make sure you get a relocation with a thermostat to help your oil get to temp quicker. I pieced together a system myself!
Old Nov 2, 2005 | 06:21 AM
msm_s2k's Avatar
You can pickup a Tru-Cool for about $80. I've used both Mocal and Tru-Cool. The $300 Mocal didn't result in any better cooling than with the Tru-Cool.
http://racerpartswholesale.com/
Old Nov 2, 2005 | 08:49 AM
Tinker219's Avatar
We are using the Tru-Cool 24 row cooler, along with all pre-fit braided stainless -10 lines, mounting plates, and of course an improved, higher flowing billet filter relocator block, than the common competitors. You should be able to install the kit in around 20 minutes As for the thermostat, we havent used one, as we just manually warm our cars up; but if we can fit it into the price, naturally we will.
That, and the turbo makes for a VERY effective oil-heater, so it should balance out because it reaches operating temperature in about 10 seconds vs. 2 minutes for coolant.
I dont have an oil temp guage, but when oil pressures would normally start dropping, they stayed VERY solid during testing, and this was with the 12 row cooler.
Next week Ill have pictures of the complete setup.
Old Nov 2, 2005 | 09:06 AM
GDM S2K's Avatar
I just picked up the B&m oil relocator and cooler for 230$ very nice piece
Old Nov 2, 2005 | 09:54 AM
wannabuy's Avatar
I went with Earl's all the way. Their billet thermostat is way nicer than the cast units on the market.
Old Nov 2, 2005 | 12:29 PM
the earls looks very nice how muhc was it and how many row? theres so many idk what to go with. for now im going to install an oil temp gauge and see how really bad id need one.
robrob
Sep 3, 2015 03:16 AM
combats2000
Jul 3, 2009 06:29 AM
