oil feed adapter? and oil line?
Old May 23, 2010 | 09:02 AM
08s2000CRbackinblack's Avatar
Default oil feed adapter? and oil line?
what size is the adaptor the goes to the "T" for the oil feed? isn't it 1/8 NPT to something? i have the "T" fitting but still need the adaptor to the block.
also the piece that i bought for the oil feed line connection to the "T" doesnt fit me oil line, i have a t3-60 and it came with a oil line on it because it was used. the fitting i bought was 1/8 NPT to 4-AN. sooo... the fitting is too large to fit the oil line. is the oil feed line to small? or is it a good size oil? possible to restrict too much oil pressure?
THANKS FOR ANY INPUT GUYS! 2 more weeks
Old May 23, 2010 | 10:31 AM
Spec_Ops2087's Avatar
Block is threaded 1/8 BSPT
Old May 23, 2010 | 12:34 PM
so that adapter piece would be 1/8 bspt - to 1/8 npt?
Old May 23, 2010 | 12:35 PM
what about the oil line? its smaller than -4 AN, thats still fine right?
Old May 23, 2010 | 06:24 PM
-3AN or -4AN works for the oil feed line to the turbo...why not just go from 1/8 BSPT to -3/-4AN. Why convert it to 1/8NPT?
Old May 23, 2010 | 06:40 PM
pwrofdrm's Avatar
Sounds like the T fitting he has is 1/8NPT...
So you'll need a 1/8 NPT to 1/8 BSPT with a 3AN male on the "T" and either a female 1/8NPT on the other end so you can put the oil pressure sensor back...
I bought a T adapter fitting on Honda-Tech that had all this combined into one block, it was only like $20 bucks.
Old May 23, 2010 | 07:09 PM
i actually found a fitting from as old turbo kit i had from my civic which fit the smaller oil line ( im guessing -3 AN) and fits into the 1/8 NPT "T" fitting i have/ so all i need now is a npt to bspt adapter. you can get these fittings at a hardware store like ACE cant you?
Emil St-Hilaire
Feb 5, 2011 07:41 PM
S2KSUPERCHARGED
Jan 26, 2011 05:41 PM
