Oil feed/return lines
I have a Garrett GT3082R dual ball bearing turbo with -.63ar hotside...I was told that it has a BB oil restrictor.
I recently ordered a -10 AN line for the oil return and a -4 feed line. I believe the feed line will fit the turbo, but there is no room on the turbo for the flange that came with the line. I can connect the line directly, but the flange is supposed to be there to restrict flow to save the seals. The -10 return line also came with a flange, and the turbo has a mounting surface for a flange, but the -10 flange is WAY TOO BIG. The feed line that was on the turbo when I got it appears to be VERY small... about half the size of the -4 line I purchased. Can anyone point me in the right direction for the lines I need? Is there a way I can used what I have purchased? Maybe buy some fittings to adapt them? HELP! |
Never mind... I just found the correct flange.
