Oil feed/return lines
Old Sep 26, 2008 | 12:36 PM
S2Krazee's Avatar
Default Oil feed/return lines
I have a Garrett GT3082R dual ball bearing turbo with -.63ar hotside...I was told that it has a BB oil restrictor.
I recently ordered a -10 AN line for the oil return and a -4 feed line. I believe the feed line will fit the turbo, but there is no room on the turbo for the flange that came with the line. I can connect the line directly, but the flange is supposed to be there to restrict flow to save the seals. The -10 return line also came with a flange, and the turbo has a mounting surface for a flange, but the -10 flange is WAY TOO BIG.
The feed line that was on the turbo when I got it appears to be VERY small... about half the size of the -4 line I purchased. Can anyone point me in the right direction for the lines I need? Is there a way I can used what I have purchased? Maybe buy some fittings to adapt them? HELP!
Old Sep 26, 2008 | 01:54 PM
S2Krazee's Avatar
Never mind... I just found the correct flange.
Forcedbird
Aug 3, 2015 04:27 PM
rikhemi
Jan 13, 2012 06:15 AM
s2kneub
Apr 6, 2009 12:28 PM
2QYK4U
Dec 6, 2006 06:54 PM
BlackS2000Turbo
Jul 12, 2005 03:51 AM
