Oil and Filter
Old Apr 1, 2011 | 03:35 AM
hondaguys2k's Avatar
Default Oil and Filter
Going boost in a few weeks and just wondering what kind of to use in the motor now? I used Mobil 1 with their filter and was just curious if there is a better oil to use for boosted cars? thanks in advance!
Old Apr 1, 2011 | 05:45 AM
SLINKYDOG's Avatar
i use joe gibbs race oil, has more zinc in it for better wear, always use a o.e.m. honda s2000 oil filter, the best out there, its a different part number. meant for higher rpms.
Old Apr 1, 2011 | 06:34 AM
Deception's Avatar
You are running an oil relocation kit? What filters does it accept, s2000 or something else?
My canton relocation took Ford v6 filters so I used an STP filter for a ford contour.
Old Apr 1, 2011 | 06:37 AM
redboost10's Avatar
Brad Penn 20-50 with wix filters.
Old Apr 1, 2011 | 06:44 AM
spectacle's Avatar
You don't need to change to different oil and filters if you're boosted. Stick with OEM spec stuff and you will be fine.
Old Apr 1, 2011 | 06:52 AM
Blucky87's Avatar
^^ I agree... for a stock engine I would stay with OEM spec oil 10w30 like mobil 1 and use OEM filters. you can buy filters cheap if you buy them in bulk from http://www.handa-accessories.com/
After I break in my new engine with regular non synthetic oil I have 2 cases of Brad Penn 15w-40 and oem filters. But I have a lowered compression built block
Old Apr 1, 2011 | 07:52 AM
yea it takes the regular s2k size filter.
Old Apr 1, 2011 | 07:53 AM
i was told AMS oil was pretty good.
Old Apr 1, 2011 | 07:56 AM
Deception's Avatar
Amsoil? Yes its a good choice, expensive though & not as easy to get.
Old Apr 1, 2011 | 08:01 AM
Kyushin's Avatar
Banned
I totally agreee here, OEM filter and a good synthetic. I use amsoil ASM 10-30 myself
