Oil pressure sensor attachment
Old Oct 30, 2006 | 05:21 PM
2QYK4U's Avatar
Thumbs up Oil pressure sensor attachment
In preparation for going boost, I purchased a Defi oil pressure gauge. According to the install manual, I should use a oil pressure sensor attachment, which is pretty much "sandwiched" between the engine and the oil filter. The install manual states that this part is "commercially available", but I have been unable to find this part.
Is anyone familiar with this part?
Old Oct 31, 2006 | 05:17 AM
pushin9's Avatar
Here is what you need...
This is part number 12002801
Here is the link to the web site
Here is one on eBay ... I also got mine on eBay
Old Oct 31, 2006 | 05:34 AM
2QYK4U's Avatar
[QUOTE=pushin9,Oct 31 2006, 06:17 AM] Here is what you need...
This is part number
Old Oct 31, 2006 | 05:42 AM
JDM S2000's Avatar
Banned
Depending on if you are going turbo, that adapter will not work with most turbo manis
Old Oct 31, 2006 | 06:21 AM
cpoz's Avatar
You can also tap into the port for the stock oil pressure warning sensor(left side of your engine, between the oil filter and Vtec solenoid). Some turbo kits use this for the oil feed though...
Old Oct 31, 2006 | 06:25 AM
John_Z's Avatar
Or you can use a remote feed like mine.
Old Oct 31, 2006 | 06:39 AM
Dsgs2k3's Avatar
i just tee off the orignal oil pressure sender.
Old Oct 31, 2006 | 07:59 AM
2QYK4U's Avatar
I am going with a CTSC.
Old Oct 31, 2006 | 08:02 AM
bigpurp's Avatar
Sure it will. You just need to sandwich it b/n your filter and the oil filter relocator.
Old Oct 31, 2006 | 08:03 AM
pushin9's Avatar
same as me .... the greddy unit is very easy and they way I would recommend.
If I remember I will try to take some pictures on my lunch break
