Oil pressure/sensor and turbo issues
Old Dec 29, 2011 | 01:57 AM
BrockB's Avatar
there is very minimal/normal shaft play, so thats fine.
thank you for the information from the article though.
Your theory with the sensor is what I hope it is. I will try relocating it with an extended line and a t fitting away from heat and vibration. I'll have to figure out a different setup for that.
As for the turbo, I'm still unsure what the issue is, even after reading the article and researching other things, but then again, it can be a lot of things the article said. I will have to narrow it down with what I can troubleshoot... thanks
Old Dec 29, 2011 | 02:58 AM
SammyT's Avatar
i have similar problem with 6765 DBB turbo. the sound is so close to this but little higher,maybe your video quality doesn't show it,
anyhow i found it's the oil inlet feed was longer than it should be so it's pushing a metal cover over the fan shaft,i replaced it with other one the sound was less but the cover was already pushed and the sound is still there. take a look at the oil feed hole and check it.
Old Dec 29, 2011 | 05:53 AM
siadam's Avatar
Originally Posted by BrockB
no... its is 100% coming from the turbo- i made sure of it. in the video, its not the regular engine tick, but the higher pitched and faster rattling noise thats coming from the turbo
My 62/62 always hummed like that, and I never had any issues with it. As long as shaft play doesn't increase, I wouldn't worry about it.
Old Dec 29, 2011 | 05:57 AM
BrockB's Avatar
i wouln't say its a hum though- its more of a higher pitched rattle. and it only started doing it recently. Im starting to wonder though, there was a time i took off the inlet oil feed line to move some stuff, and i didnt ut the connecting restrictor back on, so it was getting more oil flow temporarily for a while, but then i switched it back. maybe that caused a problem, especially being ball bearing- assuming there is a problem, that is...
Old Dec 29, 2011 | 05:59 AM
spectacle's Avatar
If you sent it to Precision and they said run with it, I'd just run with it. No sense in worrying about something you can't control.
Old Dec 29, 2011 | 06:00 AM
spectacle's Avatar
What size restrictor are you running?
Old Dec 29, 2011 | 06:08 AM
BrockB's Avatar
not sure- i left it on the turbo when i mailed it in... im waiting to get it back.
Why, what size should it be?
Old Dec 29, 2011 | 06:27 AM
FullBlown's Avatar
Former Sponsor
Remote mount it with a -3 or -4 AN line. That is a very bad spot for a sensor.
Old Dec 29, 2011 | 07:06 AM
BrockB's Avatar
what size oil restrictor should I have for ball bearing 62 precision turbo?
.035? and should run to, or will i fine with one .35?
Old Dec 29, 2011 | 07:24 AM
BrockB's Avatar
nevermind. called precision and they said their turbos have a built-in oil restrictor so another one is not neccessary. I guess that eliminates excessive oil to the turbo as a possible problem to my smoking issues, unless anybody has something to object on that...
