Oil for supercharger setup
Old Oct 29, 2015 | 07:17 PM
KiNgKoNg723's Avatar
Default Oil for supercharger setup
Hey guys i just wanna know how many quarts of oil is everyone running and what kind is best for a Sos stage 2 boosting maybe 9-10lb?
Old Oct 30, 2015 | 05:47 AM
Topplayer's Avatar
5-6 I like brad pen.
5-30 some times 10-30 depending on the time of the year, works great for me on track with that setup for 4 track season. 13lbs boost
Old Oct 30, 2015 | 02:55 PM
Yeah cause I was told our car takes 5.5 quarts of oil, but that's when I was NA.....
Old Oct 30, 2015 | 03:05 PM
Chance S2K's Avatar
If you're still using the stock oil filter location your oil capacity should only go up by like .25 -> .5 a quart I think. I forgot how much oil I had to put in last time...
I use Amsoil Signature series, 10w30.
Old Oct 31, 2015 | 01:50 AM
pwrinxs's Avatar
I just changed my oil last weekend and I used 5.5 quarts of Amsoil Signature 10w30. I am SOS2 boosting 7-8psi.
Old Oct 31, 2015 | 10:42 AM
s2000Junky's Avatar
I felt most comfortable using 5/40w. With the increase in oil temps I liked having a step up in the hot viscosity. Oil pressure should be slightly improved as well which will fall with the addition of a supercharger plumbed into the system. If you actually get all the oil out of the pan during your drain you will typically get 5.5q in without the blower. I regularly added 6q with the blower. It takes .5q.
Old Nov 6, 2015 | 10:12 PM
Thanks a lot guys... I was reading the SOS instruction and it only said to add back in 5 qt....
Old Nov 7, 2015 | 06:35 AM
JUSTINTHECOASTIE's Avatar
I like the shell rotella T6 stuff
Old Nov 7, 2015 | 10:52 AM
soulicious's Avatar
I usually add at least 5.7 quarts of amsoil 10w-30. I've been running 18psi for over three years and 10psi for three years before that. My engine is still in good health having 1% leak down and 239-240 compression across the board.
Old Nov 7, 2015 | 11:18 AM
chefs2000's Avatar
Rotella t6 it has added nutrients !
