An Old Timer Needs Some Help
Old Oct 7, 2008 | 01:55 PM
fperra's Avatar
Default An Old Timer Needs Some Help
I haven't driven my car for the last twelve month because I couldn't get it inspected which meant no registration. So it has been in the garage with an occasional slow drive down my driveway to circulate fluids. The last time I did drive it last September (2007) on the way home it developed a problem. The drive started out fine but about 10 miles from home the car started stumbling and wouldn't make any power. Whenever the engine went out of a high vacuum area of operation More than -4 in-HG) it would go extreemley lean (1.7 lambda). I was able to limp home at about 15 mph.
Since this year is an even one, no inspection is required, and the car is registered again. But the problem persists. I've checked everything I can think of related to vacuum; I've changed the MAP, fuel pump and fuel pressure regulator, but all to no avail. The car starts fine, idles fine and revs fine in neutral. But as soon as the engine is loaded, it goes way lean and stumbles. Anyone have any suggestions as to what else to look for?
Old Oct 7, 2008 | 04:13 PM
fperra's Avatar
I should add that I'm running an AEM cpu and an AEM injecter driver. I have a spare injector driver, maybe I'll switch that out and see what happens.
Old Oct 7, 2008 | 04:53 PM
AndyFloyd's Avatar
i know this most likely isnt it but, what fuel pump are you running?
Old Oct 7, 2008 | 05:46 PM
fperra's Avatar
Walbro pump. I changed that out too and it didn't solve the problem.
Old Oct 7, 2008 | 06:42 PM
snakeeater's Avatar
So many variables, especially with your totally custom setup, that it's hard to start. 1.7 lambda = 25:1 a/f ratio! Is that right? Do you trust that O2 sensor reading? Is the gasoline in your tank a year old? Did you put fuel stabilizer in it? So much for the easy stuff.
After sitting for a year, I would imagine the mechanical parts might get rusty/sticky from lack of use. Injectors, WG, BOV, FPR, ITB/TPS linkages seem more likely to cause trouble than electrical/electronic stuff. Course I've seen rats eat wires on vehicles that sat up for a while. I once had to replace a fuel pump relay because it was full of ants. I went offshore for a week, parked in a field, and ants LOVE the sweet shellac or varnish coating on the coil wire. Must have been hundreds of them in that relay!
I imagine you will need to log everything in EMS to get a handle on this. Good luck and glad to see you once again posting on the forums. Even if it's for a headache like this. I really am awed by your engine setup, BTW.
Old Oct 7, 2008 | 06:56 PM
SOHCmyDOHC's Avatar
You running a 1012 or 1052?
Old Oct 7, 2008 | 07:28 PM
fperra's Avatar
Old Oct 7, 2008 | 07:37 PM
fperra's Avatar
I had only about 2 gallons of gas in the tank before I parked it. But the problem started before that. I did start it up regulary for the past year, and about once a month I drove it up and down the drive way. Not fast enough to get it to sputter. but enough to circulate all the fluids. I changed out the fuel pump about a week ago and inspected the fuel tank. No rust or gunk in there. everything looks normal. I'm kind of leaning towards the injector driver. I'll do some dataloging s when the weather clears up (next Saturday) and go from there. Until then I'll have to be satisfied driving my '08 ZO6.
Old Oct 8, 2008 | 06:16 AM
snakeeater's Avatar
Nice backup plan!
Old Oct 8, 2008 | 02:49 PM
Jacko's Avatar
Keep us posted I'd like know what happen.
I look at your build thread like once a week you have the nicest setup I have seen on this site. I read it and
