overboosting, now underboosting.
Old Jul 17, 2019 | 01:58 PM
yamaha6611's Avatar
Default overboosting, now underboosting.
the vaccuum lines that were coming out of my charge pipe, well.. broke out. so i replaced it with a T which sends the ports directly to the wastegates.
well, it turns out that the thing on the charge pipe must have been bleeding out just a tiny bit of air, and now im only making 11psi instead of 15psi.
what are some good options that are easy to get that pressure back? its all 3AN braided lines to the gates, so i was thinking of drilling a tiny hole in each AN fitting near the gates to bleed some off, but ovbiously i need the bleed to be equal between both lines... mabye drill a hole in the 3AN T fitting?
Old Jul 17, 2019 | 02:27 PM
Charper732's Avatar
dude....get a damn boost controller. if you have a standalone get a 4 or 3 port. If you don't, get a manual controller
Old Jul 18, 2019 | 12:17 PM
yamaha6611's Avatar
I just bought a 2nd house, all the money is going there right now. In the future, sure... but for now i just want a reliable fix to get it back up to 15psi lol
Old Jul 18, 2019 | 03:26 PM
Charper732's Avatar
"reliable" ...drilling a hole to try and bleed off boost does not fit into that category. If you cant afford a $30 boost controller, I dunno what to tell you.
Old Jul 18, 2019 | 09:38 PM
s2000Junky's Avatar
Run 11psi. When you can afford to own a turbocharged s2000 you can up the boost back to 15psi then. Save your drivetrain in the meantime. If you cant afford a boost controller you definitely cant afford a rear end or transmission.
Old Jul 19, 2019 | 04:44 PM
HPC's Avatar
HPC
Get a cheap manual boost controller if you’re really desperate. Far from ideal but should be ok for the meantime. Does you tune have a boostcut?
rocy
Aug 16, 2024 05:37 AM
Dillon_93
May 20, 2016 03:57 AM
ExeC
Nov 14, 2015 09:46 AM
fltsfshr
Jul 26, 2011 10:25 AM
markS2kcU
Aug 2, 2004 08:38 PM
