Passman's Turbo Build
Old May 15, 2014 | 05:07 AM
passmans2kny's Avatar
Default Passman's Turbo Build
Well here it is guys, third times a charm right? I have redone a good amount of my set up this time around, will be retuning sometime around early to mid june, onto the list of parts, a lot is the same as b4 but theres a few changes in there.
Engine
f22
ap1 head
darton mid sleeves
weisco 11:1 pistons 87.25mm
crower rods
fbm H11 head studs (100ft/lbs)
ferrera valves
titanium retainers
ferrera dual valve springs
ap1 intake cam, ap2 exhaust cam
oem head gasket
hardrace/megan motor mounts
built by big Mike at machine world
Fuel System
fbm dual hanger w/ dual 340 fb pumps
-8 feed -6 return all stainless line
fbm fpr w/ gauge
fid 2000cc injectors
fbm fuel rail
fuel lab fuel filter
SOS flex fuel sensor and kit
Zeintronics ethanol gauge (blue led)
Boost
borg warner efr 8374 twinscroll 1.05 ar
full race twin scroll manifold
full race 3" down pipe
dual tial mv-s wastegates
Force Fed Engineering Charge pipes w/ vanjens
Drivetrain
fbm v160 conversion kit
toyota v160
clutchmasters 725 series twin disc clutch
fbm 8.8 rear end conversion
8.8 rear end, 3.89, eaton posi
fbm/avid diff mounts
steel drive shaft
Electronics
aem infinity w/ jumper harness
kenne belle boost-a-spark
stock coils
aem boost control solenoid
aem map sensor
aem fuel pressure sensor
defi gauges - oil pressure, boost, coolant temp
aem serial gauge
ngk iridium 9 spark plugs
speedohealer
Cooling
koyo radiator
mishimoto radiator hoses
13 inch dual pusher rad fans
T1 over flow tank
mishimoto thermostat
Misc
ffe 3" exhaust
ebc black slotted rotors
ebc green stuff pads
sos stainless brake lines
jic magic flta2 coil overs
ssr type c wheels(bronze)
nitto nt01 tires
matte grey vinyl wrap
forbidden oem style 4x4 carbon hardtop w/ replica oem hardware
apr side mirrors
kings bumper duct
cr lip
lots of other stuff I cant remember
comptech sway bars
Old May 15, 2014 | 05:08 AM
new charge pipes with vibrant quick connections, new efr 8374 turbo, new flange on dp for the efr, loving the new dump tube force fed made me 2-1 merge, new fid 2000cc injectors
more views of the charge pipes, new exhaust by ffe, got the aem infinity with jumper harness, installed the sos flex fuel sensor, fuel pressure sensor installed on the fpr for the infinity, got some slotted rotors with green stuff pads, also got some ssr wheels last year
Old May 15, 2014 | 05:09 AM
reserved pics coming later
Old May 15, 2014 | 05:13 AM
lude92_si's Avatar
power goal?? Nice setup man!
Old May 15, 2014 | 05:14 AM
baZurk's Avatar
Awwwwwww shit! BUILD THREAD!!!!!!!!!!!!!!!!!!!!!!
Old May 15, 2014 | 05:19 AM
illestrolla's Avatar
So much vanjen jealousy.
Can't wait to see this mang.
Old May 15, 2014 | 05:31 AM
spectacle's Avatar
Old May 15, 2014 | 05:42 AM
^^^^^ Matt in action.
Old May 15, 2014 | 05:49 AM
1SlowSi's Avatar
^lmao!!!
