Pcv
Old Aug 4, 2012 | 09:24 PM
jpetch05's Avatar
Default Pcv
Way do you guys start doing PCV wise once you start seeing some higher boost numbers. I've seen a few options around but what do you guys reccomend ?
I'm on oem PCV for an 02 as of now at 14 lbs. but I will be seeing 20+ soon here.
Old Aug 5, 2012 | 05:35 AM
s2knoob89's Avatar
Get rid of the pcv and vent the port on the valve cover to atmosphere. Cap the port on the manifold.
Old Aug 5, 2012 | 08:27 AM
99SH's Avatar
I too vent both ports on the valve cover to my catch can. Remove the PCV valve entirely.
Old Aug 5, 2012 | 05:14 PM
gettin it's Avatar
What happens if you don't?
Old Aug 5, 2012 | 05:39 PM
manny-s2000's Avatar
On the advice of some members on here I am going to gut mine out.
Old Aug 5, 2012 | 05:49 PM
99SH's Avatar
If you don't, I'd recommend adding the Supra PCV to ensure that you're not positively boosting your crankcase.
Old Aug 6, 2012 | 02:35 AM
gettin it's Avatar
I understand the point of venting the crankcase, but what if you just leave everything like factory. What will happen?
Old Oct 10, 2012 | 06:10 PM
OHclassic's Avatar
+1.
Old Oct 12, 2012 | 12:55 AM
YFZ450's Avatar
I can imagine without efficient pcv, the life of the motor would be very short relatively speaking. Weld two 10an bungs onto the valve cover, above the plate. If you leave the pcv the way it is your motor could be inhaling nasty oil vapor and the pcv would not be adequate for boost. There is so much pressure inside that valve cover in boost its crazy. That pressure is no bueno because it would be pushing down on the rings.. i think
Old Oct 12, 2012 | 04:38 AM
OHclassic's Avatar
Gracias...geting oil catch can put in very soon !
ragtophardtop
Oct 18, 2021 06:38 AM
sodiboy
Jan 21, 2013 10:09 AM
john82389
Jun 20, 2012 02:42 PM
s2jerris
Sep 20, 2011 05:55 PM
quicsvr
Jun 5, 2003 07:16 PM
