Pick my precision..
Old Apr 1, 2011 | 12:00 PM
JoeyBalls's Avatar
Why Precision?
They seem to fail the most, no way I would ever touch one. I say Garret, or Borg Warner..........
Old Apr 1, 2011 | 12:27 PM
Honda_Mad's Avatar
Originally Posted by JoeyBalls
Why Precision?
They also seem 2 be making the most power:-)
Old Apr 1, 2011 | 02:41 PM
JoeyBalls's Avatar
he's looking for 450 max though..............
Old Apr 1, 2011 | 05:34 PM
InductionPerformance's Avatar
Why Precision?
Usually a reason why they fail. A lot has to do with installation. We use Precision day in/out at 14lbs - 50lbs with little to no issues.
Old Apr 2, 2011 | 12:46 AM
Corey Maurer's Avatar
My honest reason for not wanting a gt is I like the air cooled design over the hassle of water cooling.. I know it's not a huge deal to run water lines but I like the no water line more power with less boost making precisions.. And yes I know they have had their issues but I've seen a lot less issues a of late and every time there is an issue it seems to be properly dealt with
Old Apr 2, 2011 | 01:42 AM
riceball777's Avatar
for your power goals and if cost was not issue you should run a garrett gtx 3071R or gtx 3076R. Turbine housing should be and open scroll .82ar with a t3 inlet and 3 inch vband outlet.
i do not recoment precision turbos over garrett.
Old Apr 2, 2011 | 03:46 AM
I have decided.. 5857 it is.. V band in and out.. now the next question.. .64 a/r or .82 a/r?
Old Apr 2, 2011 | 11:51 AM
Redline S2K's Avatar
82. You and your engine will be happy you did.
Old Apr 2, 2011 | 11:58 AM
camuman's Avatar
Go with a different manifold. U will be happier. Epic emap with a log pushing powa.
Old Apr 2, 2011 | 12:48 PM
I was thinking about the ELT but I dont want enough power to warrant it.. the log can handle up to 500ish and thats where I would push to.. so no need to spend the money on the ELT.. when i decide to crack open the motor and go big i will be upgrading to a 6265 and a divided ELT
