piecing together your own turbo kit
I've been doing some research and I've found few of the things I want in my kit and some of the things that I don't know if it needs to be included.
I do want the GT3076R ballbearing turbo, with t3 flange and a header custom made so the turbo could sit in front of the engine or closer to the front.
I do know that I want to have a custom down pipe and exhaust made to my spec.
I want the oil cooler to be included in the kit (which I don't know what the best way to go about as far as mounting and figuring out how much more oil it may need.)
3mm gasket and some engine work.
greddy emanage (because I have emissions so AEM EMS is out the door)
and I'm not sure if I have to tap the oil line into the engine block or from the oil pan for the turbo... coolant would be used for the turbo as well (oil and water cooled).
front mount is given, with custom bent/welded piping so it'll have less popping off the hoses.
now the manifold, I think I saw one that does what I want to do, which is no name company, i don't know how reliable it is...
i need to do a lot more research for this and I'm not doing everything until next year, but I wanna get a head start so maybe this could be my progress/research/Q&A thread...
any help would be great.
This information is really no good. We need to know what you are looking at as far as power or looks or what. A custom kit is pointless if you don't know what you are going after. It sounds like you need to do some research and get an idea of what you are going for. Or at least fill us in as far as what that may be.
