PISTONS
I've been searching this for about an hour and coming up with to much info but no answers
What I found was either Wiseco pistons or JE pistons.
Wiseco has different sizes and I need to sleeve my engine so should I just go 20 over with the 8.8 CR or keep it standard with 8.8 or what? What does going 20 over give your engine?
JE pistons were 9 CR and thats about what I should have with my thicker headgasket. I don't want to lose any power. Would a .2 CR make a big difference?
Thanks...
Thanks...
I have stock bore pistons from Arias. They're 9.5:1 compression ratio. I'm running the stock bore because I wanted more wall thickness between the cylinders due to the turbo and the ability to bore out the sleeves later if necessary.
Tim
Tim
