PISTONS
Old Nov 30, 2007 | 06:03 AM
Peter@ISP's Avatar
Former Sponsor
your not going to loose any hp by lowering your compression. you might loose hp at same boost level but with lower compression you can run more boost
Old Nov 30, 2007 | 08:32 AM
Yels2000's Avatar
Yes But I have a supercharger and it'll be the same boost that i had before around 11 psi. and I put down 390whp that was with the 2mm headgasket which I believe lowered the compression to 9:1, now I'm going with pistons instead and wondering if I'll loose a lot of hp with dropping it .2 cause I can get those pistons alot cheaper then the other ones.
Old Nov 30, 2007 | 09:14 AM
Sideways's Avatar
Changing 0.2 on the ratio should be undetectable by the butt dyno. I changed my ratio by 1.0 and I don't feel it.
Old Nov 30, 2007 | 09:28 AM
blackey's Avatar
You should actually gain HP from using a stock headgasket with 8.8 vs a 2mm headgasket at 9.0. The thinner headgasket will give you a much better quench.
Bill
Old Nov 30, 2007 | 10:11 AM
Yels2000's Avatar
Thanks Bill I was wondering that.
bewareofthepoop
41
Feb 17, 2013 12:38 PM
hondabim
Aug 22, 2009 01:59 PM
fadiss2k
Sep 19, 2008 05:03 AM
