Please help me :(
Old Sep 11, 2015 | 07:02 AM
just1reel's Avatar
Default Please help me :(
So I should start by saying thank you for reading and potentially helping me.
So my friend decided to take the greddy turbo kit off of his 08 scion tc. I want to take this kit and build it in my S. Can anyone tell me if the intercooler would fit on an s2000 it's a greddy type 31v intercooler. That's pretty much all i know about it. Td05h-18g is the turbo, I am buying a pfab down pipe and manifold. I think I need a wastegate and a dump tube? Also will likely need injectors and a new fuel pump? My S is a 2006 and I would like to push 330-360 whp at round iuno 10-12 lbs of boost. Thanks again guys any help would be appreciated.
Old Sep 11, 2015 | 08:25 AM
skinsfn36's Avatar
You can probably make the IC fit, but if I recall correctly, the S2000 Greddy kit has the Type 28.
The Turbocharger off the scion kit has an internal wastegate, so you don't need a external wastegate and dumptube. I believe the turbos specs are very similar, if not the exact same.
This is going to be a big pain, all you can basically use is the turbo and the intercooler, and unless you're buying it for virtually nothing, it won't be worth it. You'll have to buy a manifold, have a custom downpipe made, custom intake, intercooler piping. Not to mention all of the fuel support, tuning also.
Do some research on turbocharging an s2000. There are a ton of resources here.
If Mid-300s is all you truly want, the S2000 Greddy kit using Hondata Flashpro as the tuning solution would probably work great for you.
youngkilla
Jan 24, 2011 02:46 AM
s2kbtos
Jun 18, 2010 09:46 AM
tunas/s2k
Apr 12, 2010 02:29 PM
mdrob_79
Oct 9, 2009 02:10 PM
