please help a.s.a.p
Old Mar 20, 2005 | 08:12 PM
lil_ant's Avatar
Default please help a.s.a.p
will the hodata gasket good for the supercharger...please let me know a.s.a.p my car is apart so I need to know before puting it in.....
Old Mar 20, 2005 | 08:43 PM
Sideways's Avatar
Go for it. Heat in the intake is bad.
Old Mar 20, 2005 | 09:19 PM
Ztec's Avatar
Keep in mind that the Hondata gasket blocks the water from flowing through the manifold/throttle body next to the bleeder valve but there is still hot water reaching the manifold through the supply coming off the thermostat housing and routing up into the idle control on the side of the manifold - I am going to cap that feed to keep the hot water from reaching my manifold and cap the open lines on the manifold or I might use that line and attach my defi water temp sensor to thet feed line! Make sure you use Locktite on your mani bolts and nuts!!!!
Fraley
Jul 12, 2017 09:11 AM
Stine
43
Jul 25, 2016 09:47 AM
Danks2k
May 15, 2008 09:35 AM
Hoobahole
Jun 9, 2005 01:32 PM
Prolene
Apr 17, 2002 11:10 AM
