PLX R500....coo stuff
Old May 5, 2005 | 12:07 AM
Gruppe-S's Avatar
Banned
Default PLX R500....coo stuff
PLX new product:
Its almost the same size as a Apexi SAFC and this will read EGT, AFR and Knock (3 in 1).
Key Features:
-Accurately measures Air/Fuel Ratio, EGT, and Knock
-Powerful 32 bit integrated processor, RAM, and FLASH technologies
-Integrated 6 Inputs for data logging (2 Speed, 4 Analog)
-Built-in amplifier for audible knock output to speakers or headphones
-Over 80 minutes of onboard memory
-4 analog outputs (User configurable)
-Fully customizable LED warning light or shift light
-High speed USB 2.0 interface
-Large dot matrix display with blue backlight
-100% backwards compatible with M-Series controllers
-Compact dash mountable design (4.75 x 2.25 x 1 inch)
-Sensor soft start circuitry, prolongs o2 sensor life
-Powerful PC analysis software included (PLX Logger Version 2.0+ Free Download)
-Field firmware upgradeable (more features added to R-500 regularly)
Introduction:
The R-500 combines 3 essential parameters (Air/Fuel, EGT, Knock) of internal combustion engine tuning into one! Whether you're on the dyno, track, autocross, street or drag strip, the R-500 can be fully customized to suite your individual application. With intuitive user menus packed with features, merged with powerful PC software, there is virtually nothing that the R-500 can't do.
Old May 6, 2005 | 06:38 AM
sirrach's Avatar
Looks pretty cool, but what does it cost? Also, if you are running AEM, can't you get that information from there?
On a side note, first thing I thought when I saw it was a gameboy
Old May 6, 2005 | 07:59 AM
timg's Avatar
The AEM ECU with WBO2 will do all of that and more (except for the speaker knock output). The normal AEM widebands (no ECU) are display or data output only- there's no datalogging.
tim
Old May 6, 2005 | 10:23 AM
honda9krpm's Avatar
does it comes with EGT sensor and +/- knock sensor?
Old May 6, 2005 | 04:39 PM
AusS2000's Avatar
That is pretty awesome! Whereas the AEM EMS/laptop/AEM Wideband solution is better there are a lot of people who haven't gone to that extent and wamt a cheaper solution. There are also AEM users who would like am always on display in the car.
As it looks very similar to the V-AFC I'm sure we'll see them mounted in radio doors in no time.
GTDRIFT
Feb 21, 2017 12:39 PM
Si2k
Dec 12, 2011 08:14 AM
