The point of no return?
Old Feb 6, 2009 | 08:10 AM
fastkx125's Avatar
Default The point of no return?
How many miles do you think is too many for a supercharger? The relase of the SOS kit has gotten me all excited. My car is a MY03 has 50,000 miles on it. I have no record of its care before 13,000 because thats when I bought it. Ever since its had Mobil 1 every 4,000 miles or so, Diff with Mobil 1 every 15,000 miles and Tranny with factory Honda oil every 30,000 miles. The car is right now tottaly stock. Thanks for your input.
Old Feb 6, 2009 | 08:14 AM
devs2k's Avatar
it should be fine; do a compression test to make sure that's at least fine, and go for it!!
Old Feb 6, 2009 | 08:15 AM
chrisg26's Avatar
Ha well my car has about 80k on it and the Greddy kit is going on soon. Let's not hope 50k is the point of no return!
Old Feb 6, 2009 | 08:23 AM
devs2k's Avatar
a local member here is pushing over 500whp and he bought the car with approx 100k on it
Old Feb 6, 2009 | 08:30 AM
flipnrr's Avatar
phils was 125k miles and did turbo pushed it and held up til he drop a built motor
Old Feb 6, 2009 | 08:36 AM
Soul Coughing's Avatar
compression and leak down test would say far more than the amount of miles on the odometer. if its a pre-02, change out the banjo bolts.
Old Feb 6, 2009 | 08:42 AM
fastkx125's Avatar
Wow for the fast replys guys, thanks alot. Good to know these motors are as good as I thought. I figured id be fine and I thought I would deff run some easy tests on the motor first. Thanks for your input guys.
Old Feb 6, 2009 | 08:58 AM
chrisg26's Avatar
I was reading up on the banjo bolts, do you think it's a necessity? Some people are saying you don't need them as long as you aren't going 100 MPH+ for long duration. *EDIT* I did some more searching, and I saw that you blew your engine within 1 hour of being FI. Yikes. Looks like another few hours that will go into the turbo install.
Old Feb 6, 2009 | 12:22 PM
dsddcd's Avatar
I believe this was 2000 and 2001 only with the 2 hole squirters
I did a compressoin test and adjusted the valves at 40K, and I have no idea about how the engine was kept before I got boosted. Everything is still running great.
Old Feb 6, 2009 | 12:38 PM
pre-02 means 00-01
However, there was actually some motors in 02 that didn't have the oil bolt squirters. Its probably a good idea to check before hand lest you need to replace your short block.
https://www.s2ki.com/forums/index.php?showt...20oil%2520bolts
