Porting experts needed, Intake manifold
What kind of HP gain is expected by porting it to 68mm? My TB is also much wider, but as I changed it with some other things I don't know if the effect is as positive as I would have also ported my intake manifold.
Can someone clarify?
Maybe also show a pic of his ported manifold intake?
TIA,
Andreas
TIA,
Andreas
TIA,
Andreas
TIA,
Andreas
Originally Posted by Spec_Ops2087,Nov 20 2007, 04:30 AM
Unless your intake pipe is larger then the stock TB (most arn't) you'll gain nothing.
I'm porting mine now, here are the stock measurements:
-throttle body bore: 62mm
-diameter of face of intake manifold: 63.70mm
(the back face of the throttle body tapers out and is also 63.70)
-diameter that will break into the IAC passage: 69.80mm
Without welding, it looks like 68mm would be the max. I'm porting the throttle body and manifold to 70mm though, 27% area increase over the stock 62mm. Aside from re-building the IAC wall, you may want to consider rebuilding the MAP sensor channel wall at the backside of the throttle body. If you bore away the inner channel wall, the path for crud to reach the sensor will be much shorter. Boring to 70mm and fixing the IAC & sensor channel look do-able though.
