Post your bosch inline pump installs
Hey guys I am doing a fuel system on my dad's s2000 and need some mounting ideas for the bosch inline pump. We are replacing all of the factory lines with bigger lines and the easiest place seems to be under the car right along where the factory lines run, but I am worried about the pump hanging too low. I doubt I would ever have an issue here because his car will never be slammed, but just incase. I may be able to mount it in the engine bay, but it is a tight fit. The trunk is another possibility we are considering.
http://www.estperformance.com/produc...fuel-pump.html
I was going to use one of these.
Don't know if it will fit but I was going to pull the charcoal box behind the driver seat and place it there.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
that's the integratged engineering surge tank, they have a dual setup as well that I'm using for my time attack build. I think the charcoal canister location would be ideal for the single if you are able to remove your evap system.
Any thoughts?
Any thoughts?
Sent from my iPad2 using Tapatalk
