post your tunes with setup info!
didn't see any other threads like this around so figured I would start one. post your setup and attach your tune obviously all use at your own risk and be smart about it!
ap1 65k
vortech 4.25" pulley
750cc+walbro
70mm header back
AEM v1 (correct ECT and IAT correction used)
http://www.filedropper.com/ap1superc...ff124mapv119_1
its a good start up map for the setup, adjust the injector battery offset to whatever injectors you're using and it will drive the car no problem you will I'm sure need to make some adjustments since no two cars are identical
ap1 65k
750cc+walbro
70mm header back
started with stock f20c, retarded 1* per psi logged knock values anything close to 2v I pulled timing. also added a couple degrees after vtec since its so much earlier then stock.
I still need to do a few more pulls and logs to get it smoother
Originally Posted by mrscbw' timestamp='1349247639' post='22054978
Just curious, how did you come up with those ignition timings?
did you set up the map to see boost? when i loaded up your tune it shows scale in vac to 0 psi. nothing in boost? you using an offset table or something?
