PPG Synchro Box - Better than you thought?
How much total are you into your trans now? Trans, swap kit, different driveshaft, shifter, etc.?
ohhh jezzz let me try to rethink it all lol
used trans 70k miles 600 bucks.... got pretty lucky locally lol
clutch kit i got for 1800
shaftmaser aluminium DS 450
serial nine shifter 450
made my own trans mount from stock mount
used plate 100 bucks
so 3400ish with trans... not to shabby.
i think fullblown kits are 3800 with TD, and need trans still... so add 6-1000 dollars
so i pieced mine together fairly cheap.
009 has longer gear setup... its amazing too for higher HP cars! With the 3.73s its perfect for 6-800HP car feels and pulls so much harder and longer.
with stock trans all i was doing was shfiting! Lol
hatrickstu (08-20-2018)
I am all for the longer gears if the car makes enough torque. Mine will do 190 in fifth on a 24.5 and a 4.08 rear Let me look up the splits and I'll post a comparison. I find it hard to believe OEM Nissan gearing is going to be better than PPG's close ratio setup.
Take home point is that the PPG is geared way closer, which is a good thing. Just pick the right reduction ratio or rear end ratio and you are going to be notably better off.
