Pre-Tuning Hints, Tricks, Tips
Old Jan 3, 2012 | 09:55 AM
jco2301's Avatar
Default Pre-Tuning Hints, Tricks, Tips
So I will be taking my car to get tuned next week and I was wondering what kind of advice or problems you guys had when it came time to tune your car.
Old Jan 3, 2012 | 10:00 AM
passmans2kny's Avatar
tripple check everything for leaks or anything that needs to be tightened, dont rev the car high at all, basicly start up, make sure everything looks in order and take it to the tuner, good luck
Old Jan 3, 2012 | 11:11 AM
sunman's Avatar
check all connections etc for oil/vac leaks, bring fresh set of plugs, make sure your boost control solenoid is working, check fluid levels (oil) and you should be golden.
Old Jan 3, 2012 | 11:24 AM
spectacle's Avatar
Read this: http://www.evans-tuning.com/pre_tuning_checklist.html
Old Jan 30, 2012 | 01:55 PM
PeopleDontFcukinPlay's Avatar
Banned
Make sure it doesn't blow up
Old Jan 30, 2012 | 02:34 PM
Deception's Avatar
make sure to bleed the coolant right.. wasted an hour doing that at a tuning session once
Old Jan 30, 2012 | 04:07 PM
Torque Obsessed's Avatar
Bring everything you think you probably won't need, because you just might.
If the tuner is installing anything, make sure you have any needed OEM parts like gaskets or injector o-rings.
Call the tuner (yes, again) and confirm the date/time and make sure they understand any mods or installation work they will perform prior to the tune.
Get there early. Bring any E-85 or race gas you plan to tune with, or fill up with pump gas just beforehand.
Pinchy
Jul 19, 2013 06:39 PM
Jonanator
Mar 8, 2007 05:03 PM
Pinky
Jul 3, 2003 03:59 AM
Ganthet
Apr 29, 2003 04:42 AM
redbullet
Mar 17, 2002 06:39 AM
