Precision 5857 or Precision 6262?
Old May 13, 2010 | 10:08 AM
Ek_Jak's Avatar
Default Precision 5857 or Precision 6262?
still deciding on which turbo to get... looking for 350-400 whp on 10lbs. which one has the has the best range for just boosting around 10lbs? or will a t3/t04e just do the trick?
Old May 13, 2010 | 10:13 AM
s2000442's Avatar
5857 will fit your need nicely for that psi and hp range. 6262 would be overkill unless you want more psi later and more than 500whp
Old May 13, 2010 | 10:16 AM
HMFIC's Avatar
Depends on your setup as well and how efficient...
Old May 13, 2010 | 10:21 AM
Ek_Jak's Avatar
saweet, thanks for the input!
Old May 14, 2010 | 03:15 AM
s2k dre's Avatar
start with a 6262, u'll be happy with it.
Old May 14, 2010 | 03:22 AM
Revenge's Avatar
I would do the 6262, that way you can upgrade your HP way up there later if you chose to. I have not seen very many set ups with the 5857, I think Mase uses it and likes it a lot though, but many of the kit owners have upraded to a larger turbo.
Old May 14, 2010 | 06:32 AM
spectacle's Avatar
5857 is a better turbo for those goals
Old May 14, 2010 | 11:54 AM
Ek_Jak's Avatar
if i were to pick up the 6262, which a/r size willl best suit my setup? .63 or .82? thanks!
Old May 14, 2010 | 01:54 PM
Spoolin's Avatar
.82 for sure.
Old May 14, 2010 | 05:36 PM
Ek_Jak's Avatar
k thanks!
