Precision 600 HP Intercooler Mounting
Old Nov 7, 2007 | 07:17 PM
stantaur's Avatar
Default Precision 600 HP Intercooler Mounting
Question for those of you who have installed the Precision 600 HP intercooler. It measures 31.5 (tank inlet to tank outlet) by 8 by 3.5 inches.
If the intercooler is oriented with inlet/outlets toward the bottom, that puts the tabs and tapped bosses toward the top. The tabs/bosses will not fit between the frame rails. However if you to notch a 2.5 inch high (measured from frame rail bottom) by 4 inch wide section out of the inboard edges of the frame, you are able to mount the intercooler further back from the grille and upwards a bit. You can also drill a hole on the outboard part of the frame rail on each side to put a bolt through that screws into the intercooler bosses. This provides the same depth from grille and vertical location of the bottom of the intercooler that is used in the 325 HP Ultimate Racing intercooler setup. And wow, that 600 Precision is just gorgeous.
So my question -- is what's described above the way that people are mounting the Precision 600 HP intercooler? Or is the Inline Pro version somewhat narrower such that its tanks fit between the frame rails?
Thanks for your insights and recommendations. I'm also open to suggestions on shops you recommend for anodizing my intercooler black. Idea is to be very low-profile when it comes to thieves casing parking lots, cops looking for reasons to hassle, and street racers looking for someone to joust.
Thanks,
Stanford
Old Nov 7, 2007 | 09:10 PM
KCSquid's Avatar
Here is a decent thread discussing mounting.
https://www.s2ki.com/forums/index.php?showt...&#entry11201126
Seems there was another but I can't locate it doing a quick search. As for anodizing due to the cast end tanks I don't think the whole thing can be done. If you find a way that works well however let me know. I for now plan to go the eastwood rattle can route.
Old Nov 8, 2007 | 05:51 AM
stantaur's Avatar
Ding ding ding ding ding. That's EXACTLY the kind of insight I needed. Thank you!
Glad I'm following the same path others have devised. Was beginning to think I should have gotten the Inline Pro, but from what the thread says even that one may be mounted lower than the way the pics with the 600 look (and the way I'm mounting mine). Also nice thing about the way we're mounting it is that it is spaced back from the front of the frame rails, allowing me to keep the stock S2000 grille.
Thanks very much for your help. Have a great one...
Stanford
Old Dec 20, 2007 | 07:14 PM
stantaur's Avatar
Finishing out my installation now and sharing some pics of the recessed Precision 600 mounting approach described above. Here are a few links to photos of what the end-product of recessing the intercooler to accommodate the factory grille. You can see the intercooler when looking straight on, but as your angle changes from knee height up to car or walking height or from the side, it's more difficult to see.
Front view, knee level
Front view, standing
There are some other shots within these folders showing the trimming of the radiator support, the way you use studs to mount the intercooler and bolt the studs on both sides of the frame, smoothing off of the tabs on the intercooler's top, etc.
Hope it's of some help to others who are considering the Precision 600 intercooler. Very happy that I invested the time to recess it. FWIW, the recessed approach also allows you to run the same intercooler pipes as what comes with the Ultimate Racing kit.
Thanks,
Stanford
Old Dec 20, 2007 | 08:26 PM
Soul Coughing's Avatar
awesome, thanks! I think i will be going down the same path as you in the coming year! I am going to buy this intercooler too. i looked for the pics of you cutting the tabs, but could not find them! Any chance you could send me them? Thanks!
Old Dec 21, 2007 | 04:34 AM
TheCarGuy2021's Avatar
Thanks! My Precision 600 is in my garage awaiting install.
Ludeboye1
Jul 11, 2017 06:57 PM
Prokaw875
Dec 23, 2016 12:18 PM
eremoy
Mar 23, 2015 07:28 PM
o'malley_808
Forced Induction For Sale
15
Jun 22, 2011 08:01 PM
pushin9
Apr 25, 2007 05:41 PM
