Precision Intercooler Problem
Old Aug 8, 2007 | 08:40 PM
  #21
SPECIAL-OPS-S2K's Avatar
interesting...
Old Aug 9, 2007 | 03:40 AM
  #22
inlinepro1's Avatar
We designed our intercooler so that there is some space between the top of the intercooler and the bumper. You still need some sort of airflow to the radiator.
When running an aftermarket radiator such as Koyo the need for air is not as much compared to the stock radiator.
With that said you do not want the intercooler shoved all the way up into the bumper and elitminating all airflow to the radiator. We do run our own endtanks now so it does fit a bit better yet still allowing airflow to the radiator.
-Chris
Old Aug 9, 2007 | 03:59 AM
  #23
Sideways's Avatar
I suggest you have a fender washer welded on the frame on each side to help carry the load. The frame is very thin and not designed to carry load in that direction. It will rip out on you over time. Nobody wants to see that.
Old Aug 10, 2007 | 06:25 AM
  #24
Venomous S's Avatar
My precision 600 was mounted a bit below and at first I minded but then I thought that my radiator needs a bit of airflow so I think it's optimal to leave some space for air
Old Aug 10, 2007 | 06:57 AM
  #25
hokies2000's Avatar
Especially if you're running the stock radiator. It gets hot - so you need airflow. I don't think it's a good idea to mount it flush.
Old Aug 10, 2007 | 07:02 AM
  #26
PeanutButter's Avatar
I have the precision up high and the stock radiator, i have yet to see temps over 195
Old Aug 10, 2007 | 07:07 AM
  #27
AirborneS2K's Avatar
That is correct, mounting the FMIC directly flush with the path of the airflow to the radiator = very bad idea. Your temps will rise, it's been proven with just adding a front liscense plate, I promise you...and that thought of extra power you thought you gained from more surface area for the ambient air to hit is gone by your excessive heat.
You should have just mounted it how it came, how it was MEANT to be mounted. Your choice, just don't come crying here if you overheat and melt something.
Peanut butter, I am willing to bet that you have an external cooler of some kind or live in a cooler climate.
Old Aug 10, 2007 | 09:12 AM
  #28
hokies2000's Avatar
Ya you must live in a colder environment or something. With these 100 degree days I see generally 205 and up to 215-217 when I'm in traffic or sitting still.
Old Aug 10, 2007 | 12:44 PM
  #29
mys2k3's Avatar
Some space is understandable for airflow but the gap that exists is a bit much.
Old Aug 10, 2007 | 01:50 PM
  #30
I'll take some pictures of my fmic to show you....
