Psi questions
Old Jan 26, 2013 | 07:16 PM
omarisramo's Avatar
Default Psi questions
Building an AP1 with darton sleeves BC rods cp pistons. I believe it to be 9:1. My question is how much boost can it handle. I've been doing some research and from my data I came to a conclusion that 16psi is high boost, but for stock cars. Plan on using id1000's and going to use 1052. Using pump gas how much boost can I run on a "high tune?"
Old Jan 26, 2013 | 07:54 PM
passmans2kny's Avatar
Let your tuner be the one to tell you this,
Old Jan 26, 2013 | 09:21 PM
gofast04's Avatar
^ yup if you trust the tuner listen to him
Old Jan 27, 2013 | 05:37 AM
camuman's Avatar
Use id2000. Let tuner tune on pump gas and on e85
I bet you make 500+ on pump and whatever you want on e85. What turbo you running?
Remember bigger the turbo more air it moves at x boost. So x boost is not the magic number to shoot for.
Old Jan 27, 2013 | 05:45 AM
gsx2004's Avatar
every tuner feels diffrently when it comes to a pump gas tune and whats "safe". i run 20psi on 93 with a fully built 9:1 motor and a gtx3582. thats just me though
Old Jan 27, 2013 | 08:57 AM
sohc_mshue's Avatar
50 psi
s2000 or 240sx's Avatar
My engine build is similar to that so make sure you use the best wrist pins you can.
Old Jan 27, 2013 | 06:40 PM
AF_BLACKBURN's Avatar
As much as your differential, trans, head gasket, and tuner can handle. 16 psi would be a good goal.
Old Jan 27, 2013 | 07:08 PM
omarisramo's Avatar
Plan on using a 6665 t4 turbo. Calling full blown soon for the rear dif kit. Stock hg. And you say wrist pins, not sure which ones I'm using. How would I know exactly?
Old Jan 28, 2013 | 08:15 AM
1SlowSi's Avatar
Wasnt it something like 58.6?
