PTuning Turbo Kit FAQ Thread
I believe they only supply one size now, and I use it all the time. If you don't use it, you will struggle to run anything less than 14 psi so my advice would be leave it in unless you plan to run over 15 psi at all time.
I am not one for complexity, but what about a motorized valve in the exhaust to restrict flow for running less than 15psi. The center would be hollow to replicate the restricting disk included with the kit. This could be wired into the ECU for lowering boost pressure in the first few gears.
JEGS Performance Products 30882: 3" Electric Exhaust Cutout Kit 1/pkg for Single Exhaust | JEGS
thanks memo the car pulls like a raped ape uptop. But i think theres more midrange and spool to be had. I think the target boost of 11psi and creeping to 16psi give it that linear feel.it feels similar to my supercharger but with aloot more pull. Im gonna put the boost regulator disc in and see if that helps.
JEGS Performance Products 30882: 3" Electric Exhaust Cutout Kit 1/pkg for Single Exhaust JEGS
-Freddy
