Pushing stock motor
Old Aug 4, 2008 | 10:29 AM
Spec_Ops2087's Avatar
Originally Posted by JoeyBalls,Aug 4 2008, 01:19 PM
IS it just more the PSI? for example my Turbo is tiny so 10PSI is a lot less air then lets say.........a bigger turbo
Right you must look at CFMs rather then psi (aka look at volume rather then pressure).
Then other things like manifold design, etc come into play.
Old Aug 4, 2008 | 10:31 AM
Here is my semi big write up on how to size out a turbocharger for your application. Some math might be involved
https://www.s2ki.com/forums/index.php?showt...&#entry13198173
Old Aug 4, 2008 | 01:17 PM
kutsujula's Avatar
Yea im making 420whp now on pump gas, thats fine for everyday but for the v8 guys running the bottles im needing some more power, im looking at 5-550 on c16
Old Aug 4, 2008 | 01:19 PM
devs2k's Avatar
GT3076 on FR mani right? how many lbs to hit 420whp?
Old Aug 4, 2008 | 01:47 PM
afwfjustin's Avatar
^Would probably take 9 or 10 to hit that with the FR manifold.
Old Aug 4, 2008 | 01:52 PM
devs2k's Avatar
all else being equal, would a twin scroll tubular manifold with a true divided housing on the turbo be more, less, or equally as efficient as a standard FR tubular manifold?
Old Aug 4, 2008 | 01:55 PM
kutsujula's Avatar
its actually a 35R now.
Old Aug 4, 2008 | 05:21 PM
I thought the only advantage with twin scroll is faster spooling but pretty much the same power output?
Old Aug 4, 2008 | 05:33 PM
devs2k's Avatar
sounds about right; i'm not really sure
Old Aug 6, 2008 | 07:11 AM
JDM_EM1's Avatar
im making 375hp on 10psi (hi boost) and 339 on 8psi(low boost). daily driven now with more than 12k boosted so far. Stock Motor, Custom kit, pump gas...
