Q: those running Comptech aftercoolers
Is this where the coolant is supposed to go for the after cooler?
a 50/50 mixture is the prefered to use for what i understand?
I just checked and it is bone dry, wonder if the previous owner ever checked it
how full should this be filled?
so fill to the tuo, run it, and then full to the top again?, I noticed there is no level indicatior.
also, that is where the coolandt is supposed to go right?
I have no idea since like i said it is bone dry it doesnt even smels like coolant at this point
First question correct and there is no indicator fill to the top. About 1/2 bottle of water wetter should suffice. Coolant goes in the radiator. If your over flow tank is dry, there may be a leak somewhere. A 50/50 honda mix doesn't need to be flushed for a few years.
the radiator coolant is fine i was refering to the aftercooler "coolant" fluid
it does go through that orifice where the arrow points in the pic correct?
Originally Posted by suprfunguy,Jan 28 2007, 03:33 PM
Yes...you are correct.
Off tot he store to get some water wetter
I hope nothiong broke form running the car w/out aftercooler fluid for so long
Yes it does. You should be able to see fluid at the hole opening. If not, Fill it until you do wuith water watter and distilled h2o. Royal purple makes a producted similar to the redline stuff and works just as well. Most likey the jamoke that owned the car before you didn't use a water preservative and it evaporated after use. It shouldn't have affecte dthe car too much since plenty of people are running non a/c setups. You will def. see more power though.
