Question about 9lb pulley for comptech
Old Aug 23, 2005 | 09:58 AM
Nick32's Avatar
Default Question about 9lb pulley for comptech
right now i have the stock pulley on my comtech kit.. i did my own custom piping to run an intercooler instead of the aftercooler and I lost a little bit of boost through the piping..
My boost gauge is reading about 5psi... before i did the intercooler piping and it was ran straight into the intake it read 7psi..
My question is.. do u think i can get a 9lb pulley and run it with my setup. without having to mess with fuel and tuning? since i am loseing boost n with the 9lb it would be around 7psi actually.
if not. what else whould i need to get to make it run safely.
thanks
nick
Old Aug 23, 2005 | 10:08 AM
home13oy75's Avatar
If you think that you will lose 7lbs with the 9lb pulley - than you should be fine just getting on the dyno and tuning with the comptech FPR. I would recommend that you go with 1 step colder plugs and gap a bit tighter.
Let me know what the dyno numbers are. I've considered going with a FMIC but have always thought that the gains with a AC would be better. Good luck.
Have any pics of the FMIC?
Old Aug 23, 2005 | 10:18 AM
Nick32's Avatar
c if that pic works.. im not good with the hosting picture thing
Old Aug 23, 2005 | 10:20 AM
Nick32's Avatar
n no, i dont think i will lost 7psi.. ,, i just thing with the 9 psi pulley i might be around 7.. since im at 5psi with the 7psi pulley
Old Aug 23, 2005 | 10:57 AM
folex187's Avatar
Is that your ESM box I see there?
Old Aug 23, 2005 | 11:44 AM
R.P.M's Avatar
I'm confused, your first post says that you have the stock pulley on your comptech supercharger, and now you are saying that you have a 7lb pulley....Someone correct me if I'm wrong, but I thought the stock pulley for Comptech was 5.5psi.
Old Aug 23, 2005 | 12:47 PM
Silver S2k4's Avatar
You should get like a VAFC or something but you don't NEED it, just maybe should have it.
Old Aug 23, 2005 | 08:52 PM
BLOWNJROCK's Avatar
you got it done!? NICE!!!
Old Aug 28, 2005 | 07:32 PM
Nick32's Avatar
where is the best place to buy a 9psi pulley... n who makes it..
also.. where do i need a smaller belt? or is there enough room in the tensioner.
thanks
Old Aug 29, 2005 | 06:32 AM
Tech2motorsports.com
they will send you a new belt too.
