Question about ARP head studs
Old Nov 7, 2012 | 07:32 AM
9krevvin's Avatar
Default Question about ARP head studs
I'm about to replace my valves in my head, and already have ARP head studs installed. With that being said, Can I reuse my ARP's? They maybe have 1500 miles on them. Any help is greatly appreciated.
Old Nov 7, 2012 | 08:10 AM
riceball777's Avatar
yes you can reuse them as many times as you want
Old Nov 7, 2012 | 08:38 AM
1SlowSi's Avatar
I've used mine 3 times without any issues.
Old Nov 7, 2012 | 09:13 AM
9krevvin's Avatar
Sweet, thats what I needed to know. Is there any difference in torque when reinstalling? I know I'll need to reapply the moly lube, but anything other than that to be aware of?
Old Nov 7, 2012 | 09:25 AM
OemEF's Avatar
That's the main selling point of APR studs, they can be re-used. About the torque, I'm not sure, I know with rod bolts, you have to account for a small amount of stretch that occurs when re-torquing. But I'm not positive about head studs.
Old Nov 7, 2012 | 10:23 AM
Irishflame27's Avatar
ARP studs are not "torque to yield" so they can be re-used multiple times without issue. The factory head bolts are "TTY" which is why you have to tighten to a preset torque value, than turn the bolt 90 degrees in 3 steps, turning the bolt like that stretches the bolt to its proper clamping load.
Old Nov 7, 2012 | 05:50 PM
o'malley_808's Avatar
If you have them out it wouldn't be a bad idea to just pick up the FBM L19 studs. There seems to be a big discrepancy on the procedure for them given new arp lube, old arp lube, torque specs etc etc. If you can afford to grab the FBM studs I would steer clear of that mess...
Old Nov 8, 2012 | 06:22 AM
bobbyrandolph440's Avatar
I just installed my ARP last night I told them to 35 65 then 95 I guess I will see how they do
Sent from my DROID RAZR using Tapatalk 2
AutoXJeff
May 4, 2017 02:16 PM
EK9MAX
Jun 19, 2009 05:01 PM
SilvCF2k
Nov 17, 2008 01:25 PM
ChefJ
Jul 26, 2007 11:42 AM
speedy4cyl
May 4, 2004 05:49 PM
