Question about supercharger oil return line oil plug
Old Jun 7, 2012 | 07:42 PM
lolls's Avatar
Default Question about supercharger oil return line oil plug
Im looking a the oil return line plug supplied by comptech for there supercharger and it looks smaller than the oem plug. The threads look like they won't fit into the pan. Is there a difference from ap1 pan to an ap2 pan ? I didn't thnk so. Also what kind of washer are you using? The oem meal one or a rubber one?
Old Jun 11, 2012 | 05:39 PM
starrman's Avatar
Pretty sure the ap1 and ap2 are the same as far as drain plug...but isn't your line equipped with an fittings?
Old Jun 11, 2012 | 07:15 PM
speedjunky01's Avatar
they both use a m14x1.5 thread on the drain plug
the return line is 1/2" I.D. so -8 AN is perfect for it (an fittings and hose are measured in 1/16" so -8an is 1/2" hose )
I used the OEM metal crush washer and a dab of hondabond sealant on the part going on the pan, my fitting is a swivel piece so turning the fitting by hand loosens it off the adapter fitting easy oil changes! lol
here is my thread its for vortech but same concept.
https://www.s2ki.com/s2000/topic/957...o-the-oil-pan/
hope this helps
Pinky
Dec 28, 2014 06:48 PM
lolls
Jun 28, 2012 02:12 PM
Spiny Norman
Sep 11, 2008 06:46 PM
bunz559
May 21, 2008 08:17 AM
UCrazyKid
May 2, 2002 01:39 PM
