Question re: Water Temps
Old Jul 21, 2008 | 05:08 PM
  #21
Spec_Ops2087's Avatar
Originally Posted by kutsujula,Jul 21 2008, 01:21 PM
what external sensor are u running?
using a nordskog water temp gauge / sending unit
Since the manual says the fans turn on at ~198F, it seems to be reading the temps very accurately.
Old Jul 22, 2008 | 09:11 AM
  #22
GoTuningTommy's Avatar
Former Sponsor
I'm also having the same problem. My temps are around 212 at a 85-90 deg day when i'm on the freeway.
On street driving, it stays at about 194.
Old Jul 22, 2008 | 09:28 AM
  #23
WashabiS2K's Avatar
when cruising, I am usually hovering around 190
Old Jul 22, 2008 | 11:03 AM
  #24
bigpurp's Avatar
[QUOTE=WashabiS2K,Jul 22 2008, 12:28 PM] when cruising, I am usually hovering around 190
Old Jul 22, 2008 | 11:14 AM
  #25
fltsfshr's Avatar
Hey Purp
Put some water in it.
If you redo the aem temp calibration chart. Have them check your tune afterward.
fltsfshr
Old Jul 22, 2008 | 11:59 AM
  #26
Series10's Avatar
Wow guys, I'm starting to feel self conscious about my set up. I have a stock radiator with stock fans and no other cooling mods other than my EMS switching the fans on at a lower temp. On at 195 and off at 188, so essentially on most of the time while driving.
Any advice from the cooling gurus? I didn't feel an aftermarket fan switch or thermostat would be prudent, given that my EMS is doing all that for me.
Old Jul 22, 2008 | 12:30 PM
  #27
Water temps should be lower on the highway then city driving
Best cooling advice...vent your hood
Old Jul 22, 2008 | 12:31 PM
  #28
Series10's Avatar
Hood is vented my friends.
Old Jul 22, 2008 | 12:37 PM
  #29
Well judging by your temps, you are well within range.
Start to worry when your seeing 230F+ coolant and 280F+ oil temps. Otherwise I wouldn't worry about it.
Old Jul 22, 2008 | 12:47 PM
  #30
Series10's Avatar
thanks for the peace of mind.
There's a dyno-day in the next two weeks that'll give me a better idea of where I'm at with my afr's and my temps once my S gets put on the roller with the wideband and is plugged into his laptop.
