Quick Emanage questions
I got an Emanage blue version from a member with the boomslang pnp harness with injector and ignition harness. With the injector + ignition harness's from boomslang I DO NOT need to purchase the harnesses from greddy correct?
I'm going to be using the emanage to run my comptech at ~7.5PSI (4 inch pulley). I think it should give be well over enough tuning ability for the mild setup I'll be running.
Originally Posted by Dsgs2k3,Oct 19 2006, 01:10 PM
tuning should be alright witht the emanage. i am hitting 11psi and i am using a VAFCII. needs to be retuned
EDIT:
After some more reasearch, I'm stopping at ~7.5PSI for now.
To run this I'm getting an emanage so I will need an AEM FPR correct? I think I am sticking with stock injectors for now.
With the AEM FPR, I do not need the comptech ESM or their FPR correct?
Thanks
Im running 7 psi with the emanage
You dont need an AEM FPR, comptech one is fine.(I think mines bad) The Emanage takes the place of the ESM with its map clamp feature.
When tuning the emanage, dont adjust air flow, just inj values in boost.
Originally Posted by revhi,Oct 19 2006, 09:32 PM
Yes, I also recommend a wideband and do some street tuning.
Here at rutgers, I'm on the formula 1 team (we build a f1 car from scratch) and I'm on the engine team. I'm learning how to properly tune an engine completly so once I get everything down I'll start tuning myself
