Radiator upgrade for turbo?
Old May 28, 2011 | 08:22 AM
JspecVtec's Avatar
Default Radiator upgrade for turbo?
When going turbo is it recommended that you get a better radiator than oem since warmer air will be entering it or does oem work fine?
Old May 28, 2011 | 08:25 AM
mezzfin's Avatar
No need for a new radiator - you need an intercooler instead.
Old May 28, 2011 | 12:07 PM
S2K-F8's Avatar
Depends on your setup. I tried to run the OEM radiator after my turbo install but ended up overheating. Had to upgrade mine.
Scott-
Old May 28, 2011 | 12:25 PM
spectacle's Avatar
I live in Tampa, arguably the most humid climate on the east coast...been boosted for over 15k and 3 years...stock radiator with upgraded fan switch and thermostat keeps my coolant temps below stock at all times.
Old May 31, 2011 | 01:41 PM
Round 3's Avatar
stock everything here. I run more water then coolant since im in florida. 70/30 water mix
Old May 31, 2011 | 04:06 PM
passmans2kny's Avatar
a more effieicnt radiator couldnt hurt, nessesary no, a bad idea, certainly not
Old May 31, 2011 | 08:14 PM
dales2000's Avatar
is a fan switch needed if you have a EMS where you can have the fans come on earlier than stock? I ask because I am considering the thermostat but not sure about the fan switch.
Old May 31, 2011 | 08:38 PM
u can set it to whatever u want with aem ems, switch not needed
Old May 31, 2011 | 11:25 PM
alanpikku's Avatar
A larger radiator is always recommend in my opinion when going boost.
Old Jun 1, 2011 | 03:56 AM
dc2-2-ap1's Avatar
If it is only used on the street then you can get away with stock. If you ever plan on tracking it then you will need a larger capacity radiator. I say get one-you can never be to safe. What is cheaper; a new radiator or replacing the head gasket or motor when it overheats and damages something.
