Re-Use IN PRO HG 3mm?
Im installing a used turbo kit on my car.
precision 6196r BB turbo
turbosmart .38mm wastegate
turbosmart BOV
650hp FMIC
Walbro Fuelpump
1000cc Injectors
3mm inline pro HG
The basic inline pro kit
Can I re-use 3mm hg?
What level of boost can I safely run? 20psi?
turbosmart BOV
650hp FMIC
Walbro Fuelpump
1000cc Injectors
3mm inline pro HG
I'm wondering the same thing... but mine is a bit different.
The guy I bought mine from only had the HG installed for a tune. Apparently he quickly realized that his problems were beyond a new HG (he had a warped head) and the engine was then disassembled... so really my "used" HG was used for less than a mile. It looks BRAND NEW and if I take a caliper to it, I'm pretty sure it will be a consistent thickness all around. If I confirm this, do you think it will be safe to use it? No BS please.
Head gaskets are relatively cheap. It isn't how long it was on the motor it's the fact the head was already clamped down on it once, and a warped head at that. Spend the money on a new gasket to be sure you have a good seal.
