Real basic pulley question
Old May 16, 2015 | 04:05 PM
amdaman's Avatar
Default Real basic pulley question
Hi guys,
Looking at the picture which way does the pulley go on the blower? Reason I ask is because I've read real conflicting things. I emailed paxton and they seem to think that the long bit faces out towards the engine bay. So the pulley shown below would have the writing facing the blower. Can someone confirm?
On my current setup I have the long part facing inwards as I thought the pulley would touch the blower housing otherwise and my belt does not line up properly this way.. And I'm pretty sure it's stuck on the shaft now and will need to be ground off.
Old May 16, 2015 | 04:10 PM
braeden's Avatar
You should be able to read the writing on the pulley when it is on the blower
Old May 17, 2015 | 09:11 AM
its duke's Avatar
you should NOT be able to read the writings on the pulley. I just installed one last month
Old May 17, 2015 | 12:16 PM
amdaman's Avatar
Hmm, still none the wiser guys!
Old May 17, 2015 | 01:28 PM
JUSTINTHECOASTIE's Avatar
flip your belt from how you have it pictured above
Old May 17, 2015 | 01:34 PM
amdaman's Avatar
already tried that - no change.
If the pulley was flipped the other way around i think it would fit perfect but not 100% that's the right thing to do..
Old May 17, 2015 | 02:31 PM
braeden's Avatar
I am looking at the SOS instructions right now and the writing is clearly visible when it is mounted.
Old May 17, 2015 | 03:02 PM
99SH's Avatar
Courtesy teamvalorracing.
Old May 17, 2015 | 04:10 PM
This ^^^^^^
Old May 17, 2015 | 04:14 PM
amdaman's Avatar
can't argue with that..
Just a note that the SOS pulley has an indent (non-writing side) that looks like its for the washer where it bolts on to though.
grantedS2k
Jan 10, 2007 11:52 PM
LonS2k
May 3, 2006 05:16 PM
530s2k
Dec 24, 2005 03:36 PM
Nobody
Jan 19, 2004 08:43 AM
