Rear Diff Bushing / Mount kits?
Old May 13, 2010 | 11:28 AM
siadam's Avatar
Default Rear Diff Bushing / Mount kits?
Let's talk.
I think a good bit of the issue w/our diff's is b/c of the differential housing flexing from the lack of support under load and power.
If we had some sort of bushing/inserts/mounts/etc to use to stiffen up the rear, I think it would help prevent some issues.
Thoughts/advice/flames?
Old May 13, 2010 | 11:40 AM
HMFIC's Avatar
Originally Posted by siadam,May 13 2010, 03:28 PM
Let's talk.
I had similar issues with my 350z.. i can't stand how sloppy the drivetrain is..
I installed solid bushings AND a brace and its tighter than a 10 year old!
Old May 13, 2010 | 11:42 AM
HMFIC's Avatar
you could also probably fill the bushings up... I forgot what its called but its like polyeurethane.. unless that was the name haha
Old May 13, 2010 | 12:41 PM
MADjdm's Avatar
Installed solid alumnum bushings on a friends 240 - the end result wasn't worth the hours it took to finish
Old May 13, 2010 | 04:47 PM
Stealth Operator's Avatar
J's Racing made a full solid replacement set. Sadly it's been discontinued. Might be lucky to still find a set somewhere.
Old May 13, 2010 | 04:48 PM
berlinas2k2's Avatar
How TIGHT is a 10 year old?
Old May 13, 2010 | 04:50 PM
HMFIC's Avatar
Old May 13, 2010 | 05:48 PM
Crackerballer's Avatar
PRISON tight
Old May 13, 2010 | 06:23 PM
s2kadrenalin's Avatar
I'm having the same discussion on another forum regarding this topic.
Anyone had experience with these? Or care to throw in their input?
https://www.s2ki.com/forums/index.php?showtopic=785613
Old May 13, 2010 | 07:15 PM
siadam's Avatar
Thats a start, although I understand the point behind them, I'm curious if they actually work.
