Removing vtec switch with flashpro
Old Sep 18, 2012 | 04:54 AM
liquidgsr's Avatar
Default Removing vtec switch with flashpro
Anyone know how to turn the vtec switch off with flashpro when removing it from the head on a 07 s2000.
Old Sep 18, 2012 | 10:18 AM
Jin_SK's Avatar
I think you can just set the window to 10k.
Old Sep 18, 2012 | 11:46 AM
liquidgsr's Avatar
that wont work as when I removed it last it made the VSA light come on and also everything else go in limp mode.
Old Sep 18, 2012 | 02:19 PM
08s2000CRbackinblack's Avatar
be more specific. do you not want vtec at all? or are you wanting to have vtec after removing the vtec oil pressure switch on the vtec solenoid? if you still want vtec without the sensor for oil pressure on the solenoid you can go into flashpro and in the vtec tab when can choose to disable this sensor. then you will have to re upload your calibration
Old Sep 18, 2012 | 03:12 PM
liquidgsr's Avatar
yes thats what I want just to take the switch out. I can't have the switch there with the manifold I am using, so I want to disable it and have the vtec controlled by the tune on flashpro.
Old Sep 19, 2012 | 02:26 PM
go into flashpro and in the vtec tab then you can choose to disable this sensor. then you will have to re upload your calibration. you can pm me if you have anymore confusion
Old Sep 19, 2012 | 06:06 PM
liquidgsr's Avatar
Thanks. Car will be tuned and not started until it is.
rasulrasulinho
Jun 24, 2015 06:24 PM
lopez14
Dec 3, 2013 06:12 PM
Xherrox
Apr 28, 2009 12:14 PM
t00kosher
Sep 16, 2004 04:57 AM
stillenfl
Mar 26, 2002 07:49 PM
