rev hard turbo
Maybe you should try contacting RevHard for one, but you would probably be better off not installing it at all. I don't want to sound like an ass, but I just think you will end up spending so much more then the initial kit that you get after you see that you won't get the performance that your looking for from it ex(better engine management like an EMS, a better manifold, etc). I have seen a few people say that they only dyno'd 270ish whp at decent boost levels, not too impressive.
ouch but i'm a big boy i can take it. i got the kit real cheep and is any of it worth any thing ? how much would it take to get the kit to do its thing? ie man. and ems . thanks i think i should done my home work
I didn't mean to sound so harsh. The kit is functional, but it all depends on what your goals are for your own car. If you are happy with under 300whp on your turbo setup then it is probably fine, but I would at least upgrade to a standalone ecu such as an EMS for tuning. What kind of Engine management does the revhard kit use? I don't even think that it comes with an emanage, and I just wouldn't trust running that on my own car. The kit is cheap, but with forced induction, and with turbo setups, unfortunately you get what you pay for. Maybe some others with this kit could chime in if I am off, but I don't think that I am.
true the rev hard kit is inexpensive, but that is mainly due to the lack of engine management/injectors. The turbo/manifold/etc can handle 400+whp no problem. The only thing i would upgrade (besides getting EMS/injectors) would be to a larger dp (3"). Other than that, the kit is solid
Kyle Ritchie
Kyle Ritchie
that sound a little better kyle thank you . where would be the best place to buy the ems @ injectors? also i did get with rev hard and they did not have a installation book any ideas? thanks again mike
