running lean
Old Feb 11, 2007 | 02:08 PM
SC-S2000's Avatar
I just bolted on my pulley and when i had it tuned, we adjusted the FPR and got like a 12.X below Vtec but as soon as it went in it would jump to about 14.8. I think the best bet would be some sort of EMS and injectors.
Old Feb 11, 2007 | 11:20 PM
yiannakos's Avatar
i hope that just the emanage will do the job and that i wont need injectors.
tomorrow is the dyno day
i will let you know
Old Feb 12, 2007 | 11:23 AM
TRBOKEV's Avatar
I have a non aftercooled CTSC with an AP2 pulley from Comptech. I dyno'd at 304 HP at 8 lbs of boost (as measured by the dyno). We were able to tune it to to what I consider somewhat safe with my highest AFR at 12.9 somewhere in VTEC (averaging around 12.4 throughout VTEC). I do run a little rich in the bottom end as a result though.
Also my car is a daily driver.
Old Feb 12, 2007 | 11:42 AM
SC-S2000's Avatar
Is that tuned with a EMS or just the FMU
Old Feb 12, 2007 | 02:25 PM
TRBOKEV's Avatar
Mine was tuned just with the Comtech FMU.
Also I had stock exhaust and cat. I hear that if you change either you run lean and the FPR can not adjust.
Old Feb 13, 2007 | 02:24 PM
SC-S2000's Avatar
that may be why I cant get mine to adjust properly . because i cant get the FMU to to take my AF lower than around 14.8 when in vtec
Old Feb 13, 2007 | 02:56 PM
TRBOKEV's Avatar
Yeah if you have exhaust or a test pipe your just plain going to run lean with that setup.
(well unless you run a 9/1 AFR below VTEC then the top might be OK)
Old Feb 14, 2007 | 01:55 AM
yiannakos's Avatar
the tuning- dyno day was canceled for friday
i admire myself because after the installation i managed to get the car home without reving more than 5,5k
i didnt drive the car for 3 days waitting for the emanage ..........
but I CANT WAIT until friday
Old Feb 14, 2007 | 05:04 AM
S_NeWb's Avatar
Does Vortech have the same problem at stock psi?
Old Feb 14, 2007 | 05:26 AM
icemans2k02's Avatar
all depends on weather conditions and elevation and so forth. i had the T1r with test pipe and i was not running lean. when winter came and the air was more dense then in summer then i noticed a change in the AFR.
