running rich
Old Aug 19, 2009 | 03:36 PM
S2SEXY's Avatar
Default running rich
ok so i put in my wideband which is pluged into the test pipe and its reading 10.0 at idle and if i try and rev it it stays there.my aem wideband i think reads between 10-17 so it is very likely that it is richer than 10.im using the greddy basemap us tk ap1.how do i remove fuel with this unit?
im running a ctsc stock boost with the stock fpr
Old Aug 19, 2009 | 04:00 PM
S2SEXY's Avatar
just pulled the plugs.they are black
Old Aug 19, 2009 | 04:11 PM
combats2000's Avatar
so get your car tuned bro
Old Aug 19, 2009 | 04:54 PM
S2SEXY's Avatar
i went ahead and adjusted this to -80 for all the injectors going up slowly from 0.it seemed to be running a bit leaner but still reading 10 on my a/f and blowing black smoke out the tailpipe
Old Aug 19, 2009 | 05:04 PM
S2oooNvegas's Avatar
I would suggest you have someone tune it who has tuned an s2k before.
What area are you in? so we can suggest some people. Be careful playing with stuff man. Id rather not see your next post be "engine failure on 7 psi, self tuned"
Old Aug 19, 2009 | 05:20 PM
Revenge's Avatar
Mine usally read 14.7 once it's warmed up. If you disconnect the battery sometimes it takes a while for it to come around. It could also be your 02 sensor.
Old Aug 19, 2009 | 05:36 PM
S2SEXY's Avatar
i removed the rear 02 and plugged my wideband in there.i wonder if thats the problem.but my front o2 is working well
Old Aug 19, 2009 | 05:42 PM
TRBOKEV's Avatar
Just know that if you drive it like that you WILL ruin that motor. I know someone who destroyed a motor in less than 25 miles running rich like that.
Old Aug 19, 2009 | 05:55 PM
S2SEXY's Avatar
yeah im not driving the car till i figure the idle fuel out first.
Old Aug 19, 2009 | 06:04 PM
S2SEXY's Avatar
also guys "get it tuned" does not help me.im running the stock greddy basemap it should not be running so rich at idle and under 4k.revenge i will try the ecu reset.thanks
