S doesn't feel as fast anymore
Old Aug 4, 2006 | 03:07 AM
Enthralled's Avatar
Default S doesn't feel as fast anymore
I'm running a stock Vortech... took a board member for a ride the other day and the S didn't feel as fast to me anymore..but he said it felt fast.Am i just getting to use to the stock boost...?
My mods: stock vortech, ACT Clutch PP.Gonna add a test pipe next week.
Maybe i need to get new spark plugs..?I've been running this setup for about a year now.
Any thoughts/suggestions...
Peace
David
Old Aug 4, 2006 | 04:16 AM
Slows2k's Avatar
Is the belt tight? Do you have a boost gauge installed? If so what's the max boost reading?
Old Aug 4, 2006 | 05:31 AM
j_c_a's Avatar
Assuming no mechanical problems that are actually causing power loss, it's probably just the natural phenomenum of getting used to the power. My turbo setup hasn't been done that long but I'm already starting to get used to 400+hp and wanting more
Old Aug 4, 2006 | 06:14 AM
Enthralled's Avatar
no...I don't have a boost gauge installed.
Old Aug 4, 2006 | 06:39 AM
Sideways's Avatar
With no boost gauge I would suggest yearly dyno sessions.
Old Aug 4, 2006 | 06:42 AM
ayS's Avatar
ayS
i need to get a boost gauges, hopefully it's a easy install!!
not to get off topic, but what do you guys recommend getting as far as gauge pods and gauge brands?
Old Aug 4, 2006 | 07:25 AM
XclusiveAutosports's Avatar
A boost gauge install is very simple and straight forward. Just tap one of you vac lines with the supplied "T" and wire power to the gauge (12v, ground, and illumination, which can all be taken from the spare slots under the dash next to the fuse box). I have a cheap $99.00 defi gauge and it matches the stock cluster very well and works good. I just went with an autometer gauge pod for the pillar as I only have two gauges and they are easy to read there.
Old Aug 4, 2006 | 07:52 AM
Sideways's Avatar
I suggest getting one with a memory. The last thing you can do is focus on the gauge while at redline and shifting. They don't make mine anymore but you get the idea.
The only other gauge of any value is this Autometer one.
Make sure you get the optional BS light.
s2konroids
Apr 12, 2010 01:13 AM
kylemonster85
Jul 31, 2007 12:51 PM
SilverKnight
May 16, 2006 07:39 PM
m00s3
Jul 25, 2005 04:16 AM
liquid215
Aug 29, 2002 05:40 PM
