s2000 turbo , clutch problem
Hi I got a s2000 turbo 385whp 10 psi
running act heavy duty clutch + street disc
but when i run hard the pedal hit`s the torpedo wall(wall between engine and copit ) and want pull back !
Got to pull back the clutch with my foot !
I bleeded the clutch fluid 2 times (4 dot) and it still like that !
but only when i drive hard !
enny tips ?
master cyl that is not good?
sorry for my bad english but im form norway !
enny tips ?
Sounds to me like both your master and slave cylinder are bad.
http://www.clarks-garage.com/shop-manual/ts-04.htm
What can go wrong with a slave cylinder?
Similar to the master cylinder, you can experience failure in a few different areas of the slave cylinder. A loss of pressure due to leaks, cracks, or torn gaskets can cause the slave cylinder to become ineffective.
Or you could have an air pocket in the master cylinder.
jepp the clutch is hitting the floor and stays there untill i take it back !
but the clutch is perfekt when im driving normal !
no air poket sins i have bleed it 2 times now so it not that !
but I`m gonna try to change the gaskets in slave cylinder and master cylinder !
and see if that helps !
enny tips ?
enny tips ?
Here is a tool I built for a local member using a 1.5" pipe coupling and pipe cap with valve stem. By pressurizing the system during bleeding you can usually remove most of the air.
