"Safe" boost level/limit?
Old Oct 17, 2011 | 12:59 PM
cmn's Avatar
cmn
Default "Safe" boost level/limit?
As the topic implies, how much boost in considered as "safe" on a stock F20C with stock headgasket? It seems like many poeple run at around 15psi, is this considered quite safe? (Of course I understand that there will allways be risks, but I think you know what I mean.)
Old Oct 17, 2011 | 01:28 PM
Vi3tBoy's Avatar
1psi-30psi
Depends on your setup.
Old Oct 17, 2011 | 01:59 PM
Kitesurfer s2000's Avatar
What i know is my mate Phil on the first mase kit tuned by mase was boosting to 22psi 604whp 99oct reving to 10.2 and he did that for 6 months then sold the car.On the other side greddy kit 14psi max.
Old Oct 17, 2011 | 02:58 PM
Torque Obsessed's Avatar
Back in the day, people said you can't boost an 11:1 CR engine.
Then 6psi kits began appearing. Much doom was predicted.
Then 8psi kits began appearing. More doom was predicted.
Then the turbo bug bit hard, and people started boosting like crazy. Many agreed that 10-12psi was "safe".
But the envelope kept being pushed. 12psi became 13psi and finally 14psi.
The correct answer to your question is to work with your tuner and have him tune the car to a level he feels is safe.
15psi is getting a bit high for a daily driver on pump gas. I'm not sure I'd go that high for a car that sees regular use. (My peak boost is 15.5psi right now because I can't get my boost limiter working, but my car is supercharged so it almost never sees that much pressure in normal driving.)
Old Oct 17, 2011 | 03:08 PM
seoul2k's Avatar
inline pro says 11psi is max on stock compression and on pump gas. with e85 or water/meth you should be able to do 14-15 safely from what innovative motorwerks says... thats totally up to you tho
Old Oct 17, 2011 | 04:18 PM
RedLineS2k10's Avatar
Stocked foged pistons is a huge safety net....there is this guy.....
http://www.youtube.com/watch?v=KUFFudEJnjk&sns=em
Old Oct 17, 2011 | 05:40 PM
HONDZLA's Avatar
im running 20lbs on a gt40.... its all in your setup and tune, these motors can handle 700hp ive seen it online and seen it in person
Old Oct 17, 2011 | 05:44 PM
timg's Avatar
Highly dependent on the turbo setup and tuning. High exhaust flow and efficiency helps improve the boost levels you can run. Log manifolds seem to have much lower boost limits. Large turbos with high flowing turbos seem capable of much more boost before running into trouble.
Tim
Old Oct 17, 2011 | 06:07 PM
EOE's Avatar
EOE
Did anyone else feel like telling the guy in the video who screamed OMG...... to STFU?
Old Oct 17, 2011 | 06:29 PM
DFWs2k's Avatar
depends on your fuel, as well as everything else that has been said
